Slic3r - how to select extruder/filament # for multiple objects in a single operation?
Perro
(@perro)
How can I select multiple objects, in Prusa Slic3r, then set the extruder number for them all in a single operation?
When a MM model is loaded into Prua Slic3r, the default is to automatically alternate extruder number selection across all objects.
I.E. Object 1 = Extruder 1, Object 2 = Extruder 2, Object 3 = Extruder 3, Object 4 = Extruder 4, Object 5 = Extruder 5, Object 6 = Extruder 1, Object 7 = Extruder 2, Object 8 = Extruder 3 etc.
For example, I have around45 objects in a print and I want to set 40 of them to use the same extruder, but the only way I can see of doing this is to change the setting for each object, in dividually, one at a time - this is a pain, error-prone, and time consuming. It would be great if I could select all relevant objects, then right-click to set the extruder number for all of them in one go.
Thanks
Best Answer by dawsmart:
You can do this now.  With the objects selected, type the number on your keyboard.
(Sorry to resurrect - Just in case anyone else comes looking for this like I did)
Postato : 26/02/2020 8:32 am
gnat
 gnat
(@gnat)
RE: Slic3r - how to select extruder/filament # for multiple objects in a single operation?
You can't in the currently released version of PrusaSlicer. Looks like it is coming in the 2.2.0 release though as the latest beta notes mention being able to do what you are asking: https://github.com/prusa3d/PrusaSlicer/releases
MMU tips and troubleshooting
Postato : 26/02/2020 4:32 pm
1 persone hanno apprezzato
Perro
(@perro)
@gnat
Thanks for the confirmation (saves me carrying on trying to figure out away).
Thanks also for the link. I look forward to the next version...
It is newly possible to change extruders for multiple objects/parts at once by group-selection and a right mouse click.
Postato : 26/02/2020 4:58 pm
dawsmart
(@dawsmart)
Postato : 10/05/2025 11:51 pm
Perro
(@perro)
Yep! It works very well!
Postato : 12/05/2025 8:06 am
Tim Stevens
(@tim-stevens)
Thank you for sharing that. I'd have never figured it out and this was driving me crazy clicking on every object!
Postato : 05/12/2025 6:41 pm
