[Rozwiązany] Selector for MMU2 as a 3d file to print myself
blatti
(@blatti)
Hi there,
I had a problem with the knife and need to reprint the selector - could someone advice where I can download it?
I wasn't able to find it at the prusa pages.
Thanks
Stefan
if you can imagine it - if you can design it - you should print it!
Make the impossible - possible!
Opublikowany : 12/06/2021 9:01 pm
blatti
(@blatti)
RE: Selector for MMU2 as a 3d file to print myself
Sorry found it
https://www.prusa3d.com/prusa-i3-printable-parts/
Opublikowany : 12/06/2021 9:08 pm
@blatti
Make sure the blade fits well, otherwise the selector will jam more than it cuts. I myself have equipped the selector with a double-edged blade so that it cuts in both directions. This change is easy to make with CAD software.
(For demonstration only: this selector is not compatible with MK3 and MK3S/+ due to other modifications)
wbr,
Karl
Opublikowany : 12/06/2021 9:55 pm
1 ludzie polubili
blatti
(@blatti)
@karl herbert - well done - it worked since one year - I will keep it for now. If it occurs once more I consider your suggestion.
I like your signature.
Opublikowany : 13/06/2021 8:39 am
