pulley motor works only when loading / unloading
nowaczyk.tech
(@nowaczyk-tech)
Hello there,
I am having peculiar problem with my MMU2S, running on MK3S:
Pulley Motor works only when loading/unloading filament and stops working at the exact moment when the print starts.
I have tried everything: flashing up-to-date and previous firmware, tightening cables, using g-codes from sample file, using default printer profiles in slicer.
Everytime: MMU loads filament correctly using pulley - and when print starts - it just stays immovable for duration of the print, when print is finished - unloads the filament.
Veröffentlicht : 30/11/2019 9:31 am
Lichtjaeger
(@lichtjaeger)
RE: pulley motor works only when loading / unloading
Yes, exactly how it should be.
Veröffentlicht : 30/11/2019 9:42 am
