PrusaSlicer "DRIBBLING VERSION" for MMU2 updated to latest PrusaSlicer 2.1.0-rc
[Risolto] PrusaSlicer "DRIBBLING VERSION" for MMU2 updated to latest PrusaSlicer 2.1.0-rc
Pagina 3 / 3
SENIORPAPOU
(@seniorpapou)
RE: PrusaSlicer "DRIBBLING VERSION" for MMU2 updated to latest PrusaSlicer 2.1.0-rc
@antimix
Bonjour, mon anglais étant very bad, ....pensez-vous mettre au point le dribbling compatible avec la dernière version de prusaslicer ??
Il me manque énormément lorsque je "travaille" en multi-matériaux.   Les filaments ressortent avec une extrémité de deux centimètres de longueur.... à l'avance Merci.
Cordialement
Postato : 09/02/2021 4:50 pm
Snag3d
(@snag3d)
@papou @antimix
im also really keen for this, id do it if i could haha, hopefully he isn't far off posting it
Postato : 12/02/2021 9:37 am
Kayl
 Kayl
(@kayl)
Hello guys,
I wanted to test this dribbling version with Prusa slicer 2.3.0, so I built the version dribbling_2.3.0.zip
Enjoy
@antimix Great job, many thanks.
@papou J'espère que cette version comblera tes attentes.
@shane-6 You can test this version
Happy printing
Postato : 12/02/2021 11:09 pm
2 persone hanno apprezzato
Snag3d
(@snag3d)
@kayl
thank you so much! no more issues when changing from 2.3 to 2.2 dribbling very happy 🙂
ill going to send you a private message just a heads up
Postato : 14/02/2021 1:46 am
SENIORPAPOU
(@seniorpapou)
@kayl
Merci beaucoup.
Je termine ma "mutation" mk3s/MMU2s vers Mk3s+/MMu2s et je teste au plus vite.
Bonne journée
Postato : 14/02/2021 6:55 am
mc_ott
(@mc_ott)
@shane-6
Just to verify, did you mean changing from dribbling 2.2 by antimix to dribbling 2.3 by kayl ?
Postato : 01/03/2021 3:30 pm
Pierre badel
(@pierre-badel)
hello Kayl
is it possible to share sources, so that it can be compiled on other platforms?
thank you in advance
Pierre
Postato : 03/03/2021 8:45 pm
Kayl
 Kayl
(@kayl)
@pierre-badel
Of course, sources are here : https://github.com/kayl669/PrusaSlicer
Enjoy
Postato : 03/03/2021 9:37 pm
Pierre badel
(@pierre-badel)
thank you very much!
easy compilation under ubuntu 20.10 (with options -DSLIC3R_WX_STABLE=1 -DSLIC3R_GTK=3 -DSLIC3R_FHS=1)
Postato : 09/03/2021 6:06 pm
SENIORPAPOU
(@seniorpapou)
Bonjour, @kayl
est-il possible d'ajouter une séquence "g-code  end" semblable pour la mmu2s utilisée en single afin d'obtenir une bonne sortie de filament en fin de traitement, sans avoir une prolongation de plusieurs centimètres ?? En supposant avoir effectué un retour en position repos (hors objet).
Merci
Postato : 30/03/2021 1:02 pm
Snag3d
(@snag3d)
Update please 😉
Posted by: @kayl
Hello guys,
Enjoy
Happy printing
Anychance of another update 🙂
Went to try do it myslef spent 3 days trying to figure it out with no luck and feeling more lost then when I started haha. Need a person with your mad skills to implement this in new versions 😉
Postato : 03/10/2021 10:52 am
Kayl
 Kayl
(@kayl)
Dribbling 2.4.0-alpha3
Update done here : https://github.com/kayl669/PrusaSlicer/releases/download/dribbling_2.4.0-alpha3/dribbling_2.4.0-alpha3.zip
Postato : 04/10/2021 7:53 am
1 persone hanno apprezzato
Sajo
 Sajo
(@sajo)
Stringing solved
Thank you, this solved my problems with stringing.
Postato : 16/10/2021 11:41 am
isometricbacon
(@isometricbacon)
Posted by: @kayl
Cheers for keeping this updated!.
I'm having a strange issue however,
When slicing a print with this variant of PrusaSlicer, when the toolchange occurs, it will attempt to switch filaments before retraction - i.e. it hasn't pulled the previous one out of the extruder, the selector will move, with the old filament still in there - and cause a jam. It will merrily keep going on its way, and then start pushing out the next filament into mid air for awhile before realising it never reaches the extruder and stopping.
I sliced the same file back in regular PrusaSlicer and didn't have this occur, but are back to my 'stringing gumming everything up' prints. Not sure if it's something conflicting with the print settings I used?
Postato : 13/11/2021 10:47 pm
Antimix
(@antimix)
I would like to thank kayl for taking care of Dribbling 🙂.
Unfortunately in those times, I had no spare time to devote to it, but I am happy that the OpenSource world it is live, and we all are like a team. Feel free to continue to develop and improve the dribbling version, since for what I have seen recently PRUSA is focussing on XL and "real" multiple extruders, so Dribbling is still the best tools for standard MMU2 multi material.
Posted by: @kayl
Postato : 25/11/2021 5:55 pm
Pagina 3 / 3
