PrusaSlicer "DRIBBLING VERSION" for MMU2 updated to latest PrusaSlicer 2.1.0-rc
[Solved] PrusaSlicer "DRIBBLING VERSION" for MMU2 updated to latest PrusaSlicer 2.1.0-rc
Page 2 / 3
rmilyard
(@rmilyard)
RE: PrusaSlicer "DRIBBLING VERSION" for MMU2 updated to latest PrusaSlicer 2.1.0-rc
@antimix
Filament is PLA.
Attachment removed
Posted : 25/09/2019 10:09 pm
Antimix
(@antimix)
Posted by: @rmilyard
@antimix
Filament is PLA.
Attachment removed
Hi @rmilyard,
try:
Cooling Moves : 3
speed first move  : 2
speed last move :  8
Dribbling moves:  3
they may be not exactly the same, but I remember I used a very similar settings.
Posted : 25/09/2019 10:15 pm
rmilyard
(@rmilyard)
@antimix
Tried those settings and changed nothing else.  Load fail on second pass.
Posted : 25/09/2019 11:40 pm
Michael
(@michael-15)
Thanks a ton for your efforts, antimix! I was able to print a 5-color model with 371 tool changes without any interventions. That was with PLA. Different brands, I used the same settings for all of them.
Another print, where I mixed PLA and PETG needed a single intervention with PETG, where the tips don't seem as perfect as with PLA. That was a model with only 17 tool changes though.
Now I am printing with a single cooling move and three dribblings, to speed up printing. Still perfect tips 🙂
Posted : 02/10/2019 10:35 am
Michael
(@michael-15)
To follow up on that: The second print with 371 tool changes was successful as well 😀 This time with only one cooling move.
I have only few mods on my MK2.5+MMU2s: I replaced the MK2.5 heat break with the MK3 heat break from Prusa, as many people here wrote, that this is vital in order to make MK.5+MMU2s work at all. Otherwise I just got rid of the buffer (I hate it! I use self-winding spools now) and installed this: https://www.thingiverse.com/thing:3233579  But I believe that both are not relevant for my success now, the biggest part is the dribbling and the heat break.
Posted : 03/10/2019 6:06 am
Antimix and Nikolai liked
Volker Jaenisch
(@volker-jaenisch)
@antimix
Building from your GH code under Debian Buster.
src/build-utils/CMakeLists.txt
looks broken to me.
Cheers,
Volker
This post was modified 5 years ago by Volker Jaenisch
Posted : 11/11/2019 4:27 pm
Antimix
(@antimix)
@volker-jaenisch
I never built it under Linux. I have compiled on Windows 10, with Visual Studio, following the initial Prusa approximate instructions.
I had to integrate all the missing "...you are skilled developer and you should know by yourself how to 😎 " steps not told, with some scripts that created all the folder structures the compiler needs.  I explained how-to in GitHub in some messages, but I have done it ONLY for Windows 10.
Basically also in Linux you need some basic libraries pre-compiled that should be installed in your development computer, and then you need to launch some shell scripts with specific linux settings that prepare the folder structure and dev environment.
Unfortunately at the moment I don't know how to set up a Linux environment. May be I will have a look, and set up a pre-compiled package if I will success.
Posted : 11/11/2019 5:51 pm
Nikolai
(@nikolai)
Posted by: @antimix
There is a dep/ folder where all required deps are being build.
I've tried to build for Mac couple weeks back and even the main branch of PS was failing. Looks like the devs doing some magic in the background in order to compile it. It's definitely not straight forward like described in the how to.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 11/11/2019 6:13 pm
Volker Jaenisch
(@volker-jaenisch)
@antimix
Dear Antimix!
I have succesfully compiled the original Prusa-slicer 2.1.0 code without any problems on Debian Buster. Doing the same with your fork does not work, because the file  src/build-utils/CMakeLists.txt in your fork see  https://github.com/antimix/PrusaSlicer/blob/master/src/build-utils/CMakeLists.txt is broken:
src/build-utils/CMakeLists.txt:
<<<<<<< HEAD
add_executable(encoding-check encoding-check.cpp)
# A global no-op target which depends on all encodings checks,
# and on which in turn all checked targets depend.
# This is done to make encoding checks the first thing to be
# performed before actually compiling any sources of the checked targets
# to make the check fail as early as possible.
add_custom_target(global-encoding-check
ALL
DEPENDS encoding-check
Cheers,
Volker
Posted : 11/11/2019 9:55 pm
Antimix
(@antimix)
@volker-jaenisch
Interesting. I will check.
May be the original Prusa repository has been changed to allow the Linux build. As you may know, the forked Repositories are not synced with the MAIN original, and they require a periodic check and update.
Posted : 11/11/2019 10:32 pm
Volker Jaenisch
(@volker-jaenisch)
Dear @antimix
The Prusa-slic3r has supported Linux builds since the beginning.
I copied the broken file from gh:master and the cmake process comes up with no problem. The build also started and is currently running. I will keep you informed of the outcome.
Cheers,
Volker
Posted : 11/11/2019 11:57 pm
Volker Jaenisch
(@volker-jaenisch)
The build failed.Here the list of broken files:
resources/profiles/PrusaResearch.ini:<<<<<<< HEAD
Übereinstimmungen in Binärdatei resources/fonts/NotoSans-Regular.ttf
src/build-utils/CMakeLists.txt~:<<<<<<< HEAD
src/slic3r/GUI/GUI_App.cpp:<<<<<<< HEAD
src/slic3r/GUI/ConfigManipulation.hpp:<<<<<<< HEAD
src/slic3r/GUI/Field.cpp:<<<<<<< HEAD
src/slic3r/GUI/Tab.cpp:<<<<<<< HEAD
src/slic3r/GUI/PresetBundle.cpp:<<<<<<< HEAD
src/slic3r/GUI/ConfigManipulation.cpp:<<<<<<< HEAD
src/slic3r/GUI/GUI_ObjectList.cpp:<<<<<<< HEAD
src/slic3r/GUI/3DScene.cpp:<<<<<<< HEAD
src/libslic3r/Format/3mf.cpp:<<<<<<< HEAD
src/libslic3r/Format/AMF.cpp:<<<<<<< HEAD
src/libslic3r/GCode.hpp:<<<<<<< HEAD
src/libslic3r/Model.cpp:<<<<<<< HEAD
Cheers,
Volker
Posted : 12/11/2019 12:37 am
Volker Jaenisch
(@volker-jaenisch)
@antimix
Any news?
I can make a new fork and join in your changes if this helps. I am no C++ hero but capable enough.
I really need your code since my MMU stucks with to big tips and I hope that your algorithm may be a help.
Cheers,
Volker
Posted : 14/11/2019 12:35 am
Volker
(@volker)
I experiencing the same Problem and I'm not able to compile a Windows version by my own (neither the original one nor the drippling). I succeeded in compiling the dependencies (with a lot of warnings), but failed by compiling the main program.
Volker
Posted : 19/11/2019 5:55 am
Snag3d
(@snag3d)
is there a 2.3 version of this slicer? im having issues switching between them since installing official 2.3.
i have no idea how do do this myself so having it compiled would be great 🙂
Posted : 16/01/2021 10:47 am
@shane-6
Hi Shane,
Prusa slicer is now full release
you can download it as part of the drivers package on this page
https://www.prusa3d.com/drivers/
Posted : 16/01/2021 12:30 pm
Antimix
(@antimix)
Hello,
I already released the"DRIBBLING VERSION" for MMU2 updated to latest PrusaSlicer 2.2.0, (get it if you don't have) and now that the original PrusaSlicer has been updated again by Prusa to 2.3.0, so I will try also to release soon a new corresponding Dribbling version.
For now I will try to close this topic, and post a new one once I will release the new 2.3.0 version.
Regards
Posted : 16/01/2021 7:26 pm
Snag3d
(@snag3d)
@antimix
I have the 2.2 version, I love how much it actually helps I have jobs with 800+ tool changes that work flawlessly thanks to the feature you added 🙂
Im really exited for the 2.3 version with dribbling and ironing 🙂
Thank you for putting this together and keeping it updated, really appreciated 🙂
Posted : 16/01/2021 10:29 pm
Yveske
(@yveske)
@antimix
Any chance of you contacting Prusa to have your mods integrated in the original version ?
Having problems with bed adhesion every morning...
Posted : 24/01/2021 7:00 am
Snag3d
(@snag3d)
@yveske
I second this this modification in the slicer is the best thing to happen to mmu
Posted : 25/01/2021 4:39 am
Page 2 / 3
