PrusaSlicer 2.4 alpha
Página 2 / 2
Xayoz
(@xayoz)
RE: PrusaSlicer 2.4 alpha
========== Rebuild All: 27 succeeded, 8 failed, 4 skipped ==========
1>------ Build started: Project: encoding-check-libslic3r_gui, Configuration: Debug x64 ------
2>------ Build started: Project: encoding-check-libslic3r, Configuration: Debug x64 ------
3>------ Build started: Project: encoding-check-avrdude, Configuration: Debug x64 ------
4>------ Build started: Project: encoding-check-avrdude-slic3r, Configuration: Debug x64 ------
2>Checking source files encodings for target libslic3r
1>Checking source files encodings for target libslic3r_gui
3>Checking source files encodings for target avrdude
4>Checking source files encodings for target avrdude-slic3r
5>------ Build started: Project: encoding-check-semver, Configuration: Debug x64 ------
5>Checking source files encodings for target semver
6>------ Build started: Project: global-encoding-check, Configuration: Debug x64 ------
7>------ Build started: Project: libslic3r, Configuration: Debug x64 ------
7>cmake_pch.cxx
7>C:\src\PrusaSlicer-deps\usr\local\include\boost-1_75\boost/geometry/util/sequence.hpp(181,1): fatal error C1060: compiler is out of heap space
7>Done building project "libslic3r.vcxproj" -- FAILED.
8>------ Build started: Project: libnest2d, Configuration: Debug x64 ------
8>libnest2d.cpp
8>C:\src\PrusaSlicer-deps\usr\local\include\boost-1_75\boost/geometry/util/sequence.hpp(181,1): fatal error C1060: compiler is out of heap space
8>Done building project "libnest2d.vcxproj" -- FAILED.
9>------ Build started: Project: PrusaSlicer, Configuration: Debug x64 ------
9>LINK : fatal error LNK1104: cannot open file 'libslic3r\Debug\libslic3r.lib'
9>Done building project "PrusaSlicer.vcxproj" -- FAILED.
========== Build: 6 succeeded, 3 failed, 15 up-to-date, 0 skipped ==========
Respondido : 13/06/2021 7:54 pm
ssill2
(@ssill2)
@xayoz
ok, how much memory do you have.  it's pretty clear the compiler ran out of heap space during your build.   I'm building on a machine with 64GB of mem.
Respondido : 13/06/2021 8:02 pm
Xayoz
(@xayoz)
12 GB RAM, 11.4 GB Useable
Respondido : 13/06/2021 8:10 pm
ssill2
(@ssill2)
That might not be enough.  I don't get a machine these days with less than 16 for even reading email and browsing the web lol.
Respondido : 13/06/2021 8:12 pm
Xayoz
(@xayoz)
no issues with any games, nor did it have any issues compiling or running the 2.3 alpha/beta series...but maybe I just have to wait until the binaries are released...
Respondido : 13/06/2021 8:15 pm
ssill2
(@ssill2)
@xayoz
well I'm just saying that 12GB is NOT a lot these days.
Each version of visual studio uses more ram than the last, etc.  you might open an issue on the PrusaSlicer github site and say you're trying to build on windows and with how much memory etc.  Those guys would know best on what the minimum requirements to build the software are.
Respondido : 13/06/2021 8:47 pm
Xayoz
(@xayoz)
got it figured out...Apparently I was still using version 16.6.3 on VS2019.  Updated to 16.10.1 and problem solved...compiled and running great
Respondido : 13/06/2021 11:41 pm
ssill2
(@ssill2)
Nice!
Respondido : 13/06/2021 11:47 pm
Espariz
(@espariz)
Hi, I don´t know if it's possible, can someone make a build to test in Mac OS X with M1 processor? Thanks!!
Respondido : 29/06/2021 9:15 pm
ssill2
(@ssill2)
@espariz
I don't have an M1 machine sorry.
Respondido : 06/07/2021 7:12 pm
Espariz me gusta
ssill2
(@ssill2)
From the last episode of Prusa Live, #29 I think, it sounded like they'd be making alpha builds available in a couple weeks.
Respondido : 06/07/2021 7:13 pm
Espariz me gusta
like_3d
(@like_3d)
>Baklin
The multi material painting icon seems to only appear in expert mode.
Please check it.
Respondido : 04/09/2021 11:50 pm
ssill2
(@ssill2)
advanced
I just synced from master and built and it shows in advanced and expert mode only, not simple.
Respondido : 06/09/2021 12:35 pm
Volker
(@volker)
Just made my first multi material with the paint on option. This is a wapon solving a lot of problems. Easy and functional. The smart fill is amazing. The only thing I'm missing is drawing a line (not with the brush) as a border. No more messing arround with Meshmixer.
Respondido : 15/09/2021 6:08 am
towlerg
(@towlerg)
Posted by: @ssill2
Just my 2 cents but I doubt that Win whatever can effectively use that much RAM, most Win programs will run quite happily with 4GB, after all Win has mechanism for swapping memory. Having said that I guess there must be some mem hog programs that require more but Prusaslicer isn't one of them.
Esta publicación ha sido modificada el hace 3 years 2 veces por towlerg
Respondido : 15/09/2021 11:09 am
ssill2
(@ssill2)
game changer
Yeah definitely.
Posted by: @volker
Respondido : 15/09/2021 11:13 am
ssill2
(@ssill2)
ram
4GB is barely enough for the OS these days.  On latest build of Win10 with with the following programs open and any background services running, I'm using 7.2GB/63.7GB:
Two Chrome Windows
iTunes
A x64 native tools command-prompt(for building prusa slicer)
Task manager
Opening PS 2.4 master build from this morning with a reasonably complex .3mf brings this to just over 8GB.   Even if your machine only had 8GB this would mean virtually every operation would require hitting swap in some fashion.
Yes, windows has swap/paging, but disk, even NVMe storage like I'm using still isn't as fast as real ram.  If you're still using spinning metal disks, good luck!  Windows is crap about what to put in swap.  Linux/unix are much better about it.  I still think ram is the single biggest upgrade you can do to your machine to get performance increase.  The more ram you have the less you're working from slow storage because of paging/swapping.
Posted by: @towlerg
Posted by: @ssill2
Respondido : 15/09/2021 11:25 am
towlerg
(@towlerg)
I'm sure you are correct although I suspect iTunes isn't helping the situation. I take your point re. STL's, they certainly do get big quick.
Respondido : 16/09/2021 1:40 pm
ssill2
(@ssill2)
mem
Yeah, I do a good deal of blender, and development stuff in vmware virtual machines so yeah, ram is my friend lol
Posted by: @towlerg
Respondido : 16/09/2021 1:47 pm
Página 2 / 2
