PrusaSlicer 2.0.0 - FINAL
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
Hi guys,
let me introduce our newest slicing software PrusaSlicer (formerly known as Slic3r Prusa Edition or Slic3r PE), which is our own in-house developed slicer software based on the open-source project Slic3r. It's open-source and you can get it in our Drivers & Apps Package. PrusaSlicer is a feature-rich, frequently updated tool that contains everything you need to export the perfect print files for your Original Prusa 3D printer.
PrusaSlicer is available for Windows, Mac and Linux
What is new?
This is the final release of PrusaSlicer 2.0.0, mostly fixing bugs discovered in the first two release candidates. The PrusaSlicer 2.0.0 is a successor of the Slic3r Prusa Edition 1.42.0-beta2.
See the project web prusa3d.com/prusaslicer for details.
Bugs fixed
  • Fixed an issue in copy / paste of objects, where if such a situation was stored into a 3MF or AMF project and reloaded, the copied object instance was shifted by half the bounding box size.
  • OSX specific: Fixed a regression issue against the rc2, where it was not possible to delete the last digit in a spin control.
  • Fixed asserts on application initialization #2272 thanks @wavexx.
  • Fixed an error, when setting the support material distance to "0 (soluble)" or "0.2 (default) and the active language was not English #2278.
  • Fixed a crash when setting the infill to 100% and the active language was not English #2279.
Supported printers:
  • Original Prusa i3 MK3S MMU2S
  • Original Prusa i3 MK3 MMU2
  • Original Prusa i3 MK2.5S MMU2S
  • Original Prusa i3 MK2.5 MMU2
  • Original Prusa i3 MK2/S MMU1
  • Original Prusa SL1
Download link:
prusa3d.com/drivers/
Please report any bug here:
github.com/prusa3d/PrusaSlicer/issues
We look forward to your feedback!
Assembly manuals
/ Knowledge Base
Respondido : 30/05/2019 10:06 am
Antimix
(@antimix)
RE: PrusaSlicer 2.0.0 - FINAL
Hello,
I did not had the feeling that PrusaSlicer 2.0 is able to handle DIFFERENT FILAMENT PRINTING  TEMPERATURE at the same time in MMU2 mode.
I have 5 filaments, each of them with its own  printing temperature 1-198/205, 2-200/210, 3-195/200 and so on.
Basically  it should use the correct temperature for each filament is using.
- Looking at MMU2 Gcode I did not notice temperature settings at tool change. Am I wrong ? Is this supported ?
- Moreover, it would be very useful a new setting: Tool change temperature to be used only during tool change and shaping.
So we could have in the filament tab:
First Layer Temperature: 210
Other layers Temperature: 200
Tool change Temperature: 218 😀
That would be perfect and would solve many issues with MMU2.
Respondido : 01/07/2019 10:29 am
I'm not an MMU user, but I'd think Tool Change g-code is where you'd want a temp command.   You'll need to research reserved words for tool ID, but I'd expect them to be available. Then a simple if then for each tool.
Respondido : 01/07/2019 7:38 pm
