Printer beeping when filament change.
jd420214
(@jd420214)
First couple of prints and everything worked fairly well now every time it goes to change filament it asks to press the button on printer and then again asked if color change was right this didn't happen first few prints. Wife getting annoyed because our little dog goes barking crazy.
Thanks William
Napsal : 03/04/2022 3:12 pm
Hi William,
are you using M600 for filament change?
(filament change by layer height?)
Napsal : 03/04/2022 4:15 pm
jd420214
(@jd420214)
RE: Printer beeping when filament change.
Joan I've just been using what the stock setup from 2.41 slicer
Napsal : 03/04/2022 7:35 pm
there are different ways to print multicolour / material prints with MMU2s
One way ALWAYS BEEPS  (Layer based colour change (M600)
another only beeps if there is a problem. (MMU2S Auto filament change)
I have created a keyfob which you may consider printing
William PLA
It's set up for PLA, and needs three contrasting colours in extruders 1,2 & 3
This model should not Bleep.
If it does Bleep, your filament sensor tower is probably out of adjustment
P.S. Don't forget to unzip the file to get the Gcode
Napsal : 03/04/2022 9:43 pm
jd420214
(@jd420214)
Joan Thanks for the help I forgot I messed with finda and it was slightly out of adjustment seems to be working well again except for some stringing.
Napsal : 05/04/2022 9:07 pm
