Multi material overload
Taelven
(@taelven)
I am just curious if anyone has played with the multi material v2 feeding the original multi material v1. The thought of being able to control and feed 20 colors/materials is kinda leaving me giddy.
Thanks
Steve
Opublikowany : 09/10/2018 11:19 am
AbeFM
(@abefm)
Re: Multi material overload
Not AS elegant, but likely a lot less trouble - you can add manual filament changes once in a while - any layer could have 5 colors but you could use as many as you'd like in the model.
Similarly, if you were motivated, you could just extend the design. This will work with more filaments, just make the shafts longer. At a certain point you'll run out of angular resolution on the selector, I guess, but it shouldn't be a problem for a while.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Opublikowany : 09/10/2018 6:48 pm
