MMU2S to MMU3 Upgrade Parts List
Zilon
(@zilon)
Hello everyone,
since the MMU2S upgrades to MMU3 are no longer available in the shop, is there a parts list for the upgrade and are all needed parts available as spare parts or pritned parts (also for self printing)? My printer is currently a MK3S. I am thinking about upgrading to S+ or even 3.5.
Best regards,
Thomas
Publié : 20/03/2025 2:29 pm
Rob
 Rob
(@rob-22)
Membre
RE: MMU2S to MMU3 Upgrade Parts List
I'd like to know this too. It was very quietly announced on 12th march that they'd stop production of older MMU variants via a single facebook post (not everybody uses facebook), also saying "we’ll only have individual parts available and a parts list". It's been a month and no other word and sight of this parts list. Been no further announcement and no part lists since.
I've been thinking of upgrading from my MK3S + MMU2S to a new MK4S kit. I'd want to carry across the MMU, so upgrade it from MMU2S to a MMU3, but have no clue how to do that now. So basically I'm seriously reconsidering even getting the MK4S atm.
Publié : 14/04/2025 11:39 am
1 personnes ont aimé
Garvey
(@garvey)
Membre
Hello,
I need also the list of parts. I saw the annoucment today and can not find anything.
Any information about this would be great
Publié : 17/04/2025 1:26 pm
Must of the hardware from MMU2S is re used
exceptions being power and data cables
mmu3 has a power distribution board new power and data combined cables, new PTFE Clips for the rear of the MMU3 and the Buffer connections,
the Buffer has longer cassettes to allow for longer rewind values,
the Filament cutter is now bi directional two cutter blades, Finda  now has a magnet to improve response when filament exits the reverse bowden section,
the PTFE tubes are now 4mmx3mm, to reduce friction
annnd,,, the plastics are different to the MMU2S plastics
hope this helps, Joan
Publié : 17/04/2025 5:56 pm
Garvey
(@garvey)
Membre
I found a list of parts
1 * MMU PD-board addon https://www.prusa3d.com/product/mmu-pd-board-addon/
1 * cable, depends on printer board -->  mk3.5 or greater https://www.prusa3d.com/product/mmu3-printer-cable-for-mk3-5-3-9-4/
        --> mk3s  https://www.prusa3d.com/product/mmu3-printer-cable-einsy/
4 * filament cutter -> not available in shop
1 * magnet 10x6x2 mm  -> not available in shop
1 * magnetic ball -> not available in shop
4 * screws M3*10 -> not available in shop
1 * motor coppler -> also missing in shop
Is this parts list correct?
The screws, the cutter and maybe the magnets are not a big problem that they are missing, but the motor coppler, I think is a problem.
Can you tell me whether this part come to your shop?
When not is it possible, to get more details about this part. size length and so on, so I could try to find it elsewhere
Thx for your help
Publié : 18/04/2025 9:18 am
PDU for mk3  Saw this on Ebay
eBay item number:396392560346
This filament sensor may help with the magnet and ball bearing.
eBay item number:293017750684
the filament cutter blades are off a modelling  knife, something like this.
eBay item number:365428863792, as you already have an mmu2, you may have a second blade in the spares pack.
If you measure the blades, you can probably match them to a cheap snap off blade knife at the dollar store/ pound shop or DIY Store.
M10 x 3 screws
eBay item number:383632777580
May be more cost effective to get a kit
eBay item number:306039992742
If you are re using an MMU2 unit, the square nuts may be difficult to get out
eBay item number:387761000870  choose M3 THIN Square nuts
the motor coupler is more difficult.
Have a look on thingiverse and printables, I am sure I have seen a printable version (Or re use the MMU2 version)
I Hope this helps,
Publié : 18/04/2025 12:29 pm
delwilson6241@gmail.com
(@delwilson6241gmail-com)
The upgrade kit is no longer available.  Parts List is available at https://help.prusa3d.com/article/list-of-parts-for-mmu2s-to-mmu3-upgrades_887521?utm_medium=chat&utm_campaign=link-shared-in-chat&utm_source=livechat.com&utm_content=www.prusa3d.com
I found it a bit confusing. Good luck with this, I'm still deciding/researching how to get there.
Publié : 16/06/2025 10:05 pm
https://www.printables.com/model/549916-printable-mmu3-coupler
Printable alternative
Joan
Publié : 08/09/2025 8:23 pm
