MMU2s Single profile question/suggestion
reddadsteve
(@reddadsteve)
I've been having absolutely no problem with my MMU prints and the tips are nice and clean at the end of the job.  However when I run an MMU2S Single job, the filament tip is quite stringy when the job completes.  Same filament and filament parameters are used.  Without any manual intervention to clean the tip, there is a good chance that it will eventually cause problems a few prints later.
Unless I am missing something, I would suggest a change to the slicer to add the same ending process to the MMU2S Single profile that the MMU profile has in order that the final tip is clean.  I do not see any parameters that I can copy directly to the ending gcode.
Teamwork,
Steve
Veröffentlicht : 18/07/2019 6:06 pm
gnat
 gnat
(@gnat)
RE: MMU2s Single profile question/suggestion
I haven't looked at the end gcode to compare single vs multi prints, but I've noticed the same thing. Similarly stopping a multi tool print results in a bad tip on the ejected filament too.
MMU tips and troubleshooting
Veröffentlicht : 18/07/2019 6:58 pm
