MMU Firmware 1.0.1 is available
Joe
 Joe
(@joe-16)
Looks like MMU firmware 1.0.1 is available now: https://github.com/prusa3d/MM-control-01/releases
Direct link to hex file: https://github.com/prusa3d/MM-control-01/releases/download/v1.0.1/prusa3d_fw_MMU2board_1_0_1.hex
There is no menu option to perform the bowden tube calibration for each pulley.
This isn't an official guide but this is how I managed to do the calibration for each filament. Please let me know if something is incorrect.
1. Keep machine off
2. Cut fresh angled tips and load 5 filaments past the pulleys
3. Turn machine on while holding middle button of MMU
4. Hold middle button during entire boot until lights 1 and 5 are the only ones lit up.
5. Press left once so 1 and 4 are lit up.
6. Press center button.
7. Now this is where it's different from before. Now you select which filament to calibrate by going left/right or pressing center to start.
8. It appears you may have to hold the center button for about a second to start the calibration rather than just tapping it.
9. Adjust the filament up/down with left/right to your desired position and press center to save and unload that filament.
10. Move on to the next filament with left/right.
11. Repeat steps 8-10 for each filament
12. Press the reset button on the MMU after saving the 5th filament.
13. After it reboots the MMU I turned off the power switch and let it reboot from scratch just to be safe.
Respondido : 11/10/2018 9:30 pm
K7ZPJ
(@k7zpj)
Re: MMU Firmware 1.0.1 is available
Thank you. Your instructions were spot on.
I now have all 5 filaments correctly calibrated. 🙂 🙂 🙂 🙂 🙂
Respondido : 12/10/2018 3:30 am
aake.e
(@aake-e)
Thanx joey.c2 !
I think I got qiuet big difference in gear size so this was needed.
Good guide, thumbs up 🙂
Mk3S+, Mk4 MMU2S never worked properly
Respondido : 12/10/2018 8:33 pm
AbeFM
(@abefm)
Miembro
It doesn't say the build number anywhere, making it hard to know if I should replace my 1.0.1-117 with this or not.
Could it be you meant "now"?
I debate on this a lot - for 99% of the changes, the tip will be as-retracted, not freshly cut, so the real concern to me is where it ends up in use.
I will trim a long string off a tip, but generally I leave an as-formed tip for the calibration.
You can exit the menu by moving selector all the way to the right (past position 5) and pressing the main button.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Respondido : 12/10/2018 9:11 pm
