Initial setup of Mk3 and MMU2
Escher
(@escher-2)
Hey guys, I purchased 2 mk3 kits, and one MMU2. Do you recommend getting the machines working first, and then put the MMU2 on it? Or is that something I should install right away on the one machine?
Opublikowany : 02/12/2018 12:42 am
toaf
 toaf
(@toaf)
Re: Initial setup of Mk3 and MMU2
I would get the mk3 working good first. BUTT before you put the hot end in use the PTFE tube that comes with the mmu kit.
too many things to worry about. take it slow
Opublikowany : 02/12/2018 1:05 am
Escher
(@escher-2)
Thanks. This is advice i need. Im going to put the mmu on the second printer so by then ill be a bit more confident.
Opublikowany : 02/12/2018 5:30 am
