How to enable Cutting in G-Code
Hello,
I have been having issues with the diameter of my hotend, so that I can print normally with a cut tip but have been unable to print with any type of rammed tip. It would be a bit wasteful, but I should be able to print if I cut the filament after each unload. However, the normal code, K{previous_extruder}, does not work when I add it to the pre-tool change gcode, and I am unable to use this code in the terminal of OctoPrint. I am able to cut from the LCD screen, and I do have cutting enabled.
Is there some way to get K0-4 working when I run gcode?
Publié : 28/05/2020 9:16 pm
