How to change layer height between a hollow cylinder and Solid one
les.b4
(@les-b4)
Hi Guys,
I am trying to make model where a hollow cylinder connects to a solid one. When i print it the solid cylinder is barely connected to the lower one.
So i was wondering with such a model can one change the thickness of this space between where the two cylinders join.
Or is there something wrong with how i done my model.
Thanks
Les
Napsal : 23/09/2018 1:33 am
Re: How to change layer height between a hollow cylinder and Solid one
can we see the STL?
Napsal : 23/09/2018 1:51 am
les.b4
(@les-b4)
Hi Joan,
Will do, just wasn't sure how but do now. Tried but an error came back "Invalid file extension) when i tried to attach an STL.
Regards
Les
Napsal : 23/09/2018 2:12 am
Hi Les,
Zip it, and post the zip file...
Napsal : 23/09/2018 2:27 am
les.b4
(@les-b4)
Yes just worked out it had to be zipped. Here it comes.
Regards
Les
Napsal : 23/09/2018 2:33 am
Enginman
(@enginman)
Hi. This is a section of your part. See anything wrong?
Napsal : 23/09/2018 4:17 am
Punkgeek
(@punkgeek)
oh yah - at the 6mm layer you have no connection between the top part and the bottom part. Did you intend for the bottom part to be filled? Because it isn't ;-). If you intended the bottom part to be hollow, you need at least a couple of layers that go all the way across.
Napsal : 23/09/2018 5:51 am
les.b
(@les-b)
Thanks Guys,
Yes i realized what i had done, and now have a base between top and bottom.
Les
Napsal : 23/09/2018 10:17 am
