How to change layer height between a hollow cylinder and Solid one
Hi Guys,
I am trying to make model where a hollow cylinder connects to a solid one. When i print it the solid cylinder is barely connected to the lower one.
So i was wondering with such a model can one change the thickness of this space between where the two cylinders join.
Or is there something wrong with how i done my model.
Thanks
Les
Re: How to change layer height between a hollow cylinder and Solid one
can we see the STL?
Hi Joan,
Will do, just wasn't sure how but do now. Tried but an error came back "Invalid file extension) when i tried to attach an STL.
Regards
Les
Hi Les,
Zip it, and post the zip file...
Yes just worked out it had to be zipped. Here it comes.
Regards
Les
Hi. This is a section of your part. See anything wrong?
oh yah - at the 6mm layer you have no connection between the top part and the bottom part. Did you intend for the bottom part to be filled? Because it isn't ;-). If you intended the bottom part to be hollow, you need at least a couple of layers that go all the way across.
Thanks Guys,
Yes i realized what i had done, and now have a base between top and bottom.
Les
