firmware or slicer? blade isn't used
Mirar
(@mirar)
I'm assuming that the blade should be used to cut strings and other debree that wasn't fully pulled back from the selector.
However, when the selector moves it's not moving in a way that would cut the filaments - it needs to take a step up/right to be able to cut the filament when moving back left (the blade cuts to the left).
Is this a Slic3r, MK3 or MMU2 firmware issue?
(Test case: The blade will NEVER cut filament number 5.)
Posted : 30/11/2018 8:20 pm
Mirar
(@mirar)
Re: firmware or slicer? blade isn't used
What is even the intended use for the blade? Is this something that was lost from prototyping?
Posted : 02/12/2018 12:15 pm
joreal
(@joreal)
It would be great if the blade or cutter function as announced. Since day 1 I never seen any cut filament.
I wish there is option to cut on every filament change to prevent jamming.
Posted : 02/12/2018 1:10 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Better to solve the cause of the problem than use a work-around which would not be 100% reliable.
Peter
Posted : 02/12/2018 2:29 pm
Mirar
(@mirar)
Are you saying the blade has no purpose?
It seems to me that it would serve the same purpose as good ramming, and a backup in case the ramming randomly generates a string. But then it should make sure it always cuts.
The blade seems to be in the wrong direction for an immediate cut?
Posted : 02/12/2018 2:49 pm
PJR
 PJR
(@pjr)
No, just saying that it's better to solve the cause of the stringing. If you cur the filament end straight with the blade, you can cause more problems.
I haven't had the blade in place since early on in the beta; the firmware does not currently implement end cutting with it. I have a feeling that the only reason it's there is for marketing purposes.
Peter
Posted : 02/12/2018 2:54 pm
Mirar
(@mirar)
If it's not used the selector could be much better crafted. I might make a version for that.
Edit:
How about this filament path? It should give less amount of snags.
Posted : 02/12/2018 11:33 pm
