Firmware 3.6.0-FINAL for Original Prusa i3 MMU2S & MMU2
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
WARNING: Note that MK3S, MK3, MK2.5 and MK2.5 are different printers! Each has its own firmware file!!!
Hi guys,
this is a final version of the firmware recommended to all users. Compared to the 3.6.0-RC1 smarter load/unload/eject" has been improved.
What is new?
-> Initial version for MK3S and MK2.5S printers with MMU2 unit
-> Smarter load to nozzle/unload/eject function for multi material printers and single material version improved
-> Stop print during filament change fixed
This the first firmware to support MK3S/MK2.5S printer with MMU2 unit. This combination of hardware is officially called MK3S MMU2S or MK2.5S MMU2S.
This feature has been recently added to firmware in 3.5.2-RC1 version, but this initial version has been working only for single material printers (without MMU2 connected). In this firmware version, it has been extended to provide similar function also for multi material printers. We also decided to change function slightly to make it more useful for most users. When a user chooses to load filament (for example) with the cold nozzle for example, preheat menu appears and both nozzle and heatbed are preheated (to save some time later when starting a print) and printer waits for the nozzle to preheat close to the target temperature (5% below target). When preheating is finished, printer beeps and the user can start loading filament. Target temperature remains the same after the load is finished as we assume that most load/unload scenarios precede starting new print.
When stopping print during the T-code execution nozzle could crash into wiping tower. This has been fixed.
Supported printers:
Original Prusa i3 MK3S MMU2S
Original Prusa i3 MK3 MMU2
Original Prusa i3 MK2.5S MMU2S
Original Prusa i3 MK2.5 MMU2
Download link:
https://www.prusa3d.com/drivers/
Firmware flashing guide:
https://manual.prusa3d.com/Guide/Upgrading+the+firmware+v1.5/66
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Assembly manuals
/ Knowledge Base
Publié : 04/03/2019 1:53 pm
 Anonyme
Re: Firmware 3.6.0-FINAL for Original Prusa i3 MMU2S & MMU2
I have tried to update my mk3/mmu2 to the last 2 firmware releases 3.5.2/1.04 and 3.6/1.05 on both occasions the printer fails with the same symptoms and I have had to revert to the previous Firmware 3.5.1/1.03 and the printer works fine. With the update everything calibrates fine and I start a print , during the first couple of layers the printer just resets and stops, it is as though the printer has just been turned on. I have tried several different models with the same result each time. There are no error messages.
Publié : 08/03/2019 1:21 pm
Roy
 Roy
(@roy)
As long as you didn't upgrade the extruder of your printer to the 3S version (means you also need the new Infrared Sensor) you can't use 3.6.0 of the MK3S / MMU2S package for the printer itself.
You need to use the firmware for MK3 instead.
Publié : 17/03/2019 6:11 pm
Roy
 Roy
(@roy)
I am getting Pre Heat Error if I use filaments with different temperature setting.
I also get this error when I change the temperature manually!
As you have to reset the printer in order to get rid off this error message, I always loose that print.
Being unable to use different temperature settings or different materials, makes the MMU2S useless.
As I am not the only having this issue, I would kindly ask to fix the firmware.
BR
Roy
Publié : 17/03/2019 6:17 pm
