Firmware 3.5.2-FINAL for Original Prusa i3 MK3/MK2.5 MMU2
Jakub Dolezal
(@jakub-dolezal)
Member Admin
UPDATE: Final version is out https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f53/firmware-3-6-0-final-for-original-prusa-i3-mmu2s-m-t28162.html
WARNING: This firmware is for the MK3/MK2.5 MMU2! Don't use it with the MK3S/MK2.5S MMU2S.
Hi guys,
this is an upgrade of the firmware for the Original Prusa i3 MK3. It is a final version recommended to all users.
Only difference compared to 3.5.2-RC1 are new messages translations and language corrections.
What is new?
-> More quiet print fan operation
-> Heatbed regulation improved
-> Improved heater temperature regulation
-> Spool join for multi-material prints
-> Smarter load/unload function
-> Mintemp for MK2.5 updated
-> SD card menu is shown automatically when the card is inserted
-> Safer communication between MMU2 and printer
-> Crash detection for zero target temperature fixed
More quiet print fan operation:
This change is significant especially for low fan speeds.
Heatbed regulation improved:
Heatbed PWM now works on a higher frequency. This helps to reduce the power supplies "clicking" noises.
Improved heater temperature regulation:
When changing temperatures during the print, temperature regulation was very slow in some cases led to preheat error. Regulation has been improved. This should solve issue #1362.
SpoolJoin for multi-material prints:
It is now possible to use the "SpoolJoin" function also with multi-material prints. If some filament is depleted, the printer replaces it with next filament for the rest of print (for example if filament 2 was depleted, the printer starts using filament 3 instead). If there is no filament which can be used (all filaments were depleted), the printer waits for the user to insert new filament manually.
Smarter load/unload function:
If a user chooses load (or unload) in the menu with a cold nozzle, nozzle preheat menu automatically appears. After selecting material, preheat starts. When the nozzle is hot and the printer is ready for a load, beeper signal occurs. This function is working on single material printers with load/autoload and unload. It is not currently implemented for multi-material printers (load to nozzle, unload and eject).
Mintemp for MK2.5 updated:
"Mintemp" is now checked after a short period of preheating. This is necessary for maximum reliability on all MK2.5 Rambo boards.
Supported printers:
Original Prusa i3 MK3 MMU2
Original Prusa i3 MK2.5
Original Prusa i3 MK2.5 MMU2
Download link:
https://www.prusa3d.com/drivers/
Firmware flashing guide:
https://manual.prusa3d.com/Guide/Upgrading+the+firmware+v1.5/66
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Assembly manuals
/ Knowledge Base
Opublikowany : 19/02/2019 1:23 pm
