Firmware 1.0.4-RC1 for the MMU2 unit
Seite 1 / 2
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
UPDATE: final version 1.0.4 is out https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f53/firmware-1-0-4-final-for-the-mmu2-unit-t27891.html
Hi guys,
this is an upgrade of the firmware for the MMU2 control board inside the multi-material unit. Keep in mind this a release candidate (testing version) for experienced users 😎
What is new?
-> Drive error detection and counter
-> Undesired unload fixed
-> Improved eject
Drive error detection and counter:
MMU2 unit can now deal with a state where Trinamic drivers were not able to provide enough power for steppers. A possible cause can be broken MMU2 power supply wiring, connectors etc. If this state is detected the MMU2 unit rehomes and automatically continues printing. If the problem occurs three times in a row, the MMU2 unit stops printing and starts flashing continuously with red and green LEDs. Also, MMU2 unit stores information about all drive errors into its memory and the total number of drive errors can be shown in the menu "Fail Stats MMU -> Total" as item "MMU power fails" (printer FW 3.5.2-RC1 and higher).
Undesired unload fixed:
There was a scenario where MMU2 unloaded filament out of Bondtech gears instead of parking it to the default position. This state needed user intervention. This bug has been fixed in the current FW version.
Improved eject:
The filament is now retracted when recovering from eject, so it doesn't get broken if the user forgets to remove it.
Supported printers:
Original Prusa i3 MK3 MMU2
Original Prusa i3 MK2.5 MMU2
Download link:
https://github.com/prusa3d/MM-control-01/releases/tag/v1.0.4-RC1
Firmware flashing guide:
https://manual.prusa3d.com/Guide/Upgrading+the+firmware+v1.4/66
Note: Use Slic3r PE 1.41.2 or latest to flash the MMU2 control board
Please report any bug here:
https://github.com/prusa3d/MM-control-01/issues
We wish you a successful calibration and look forward to your feedback!
Assembly manuals
/ Knowledge Base
Veröffentlicht : 08/02/2019 12:01 pm
Jim
 Jim
(@jim-11)
Re: Firmware 1.0.4-RC1 for the MMU2 unit
Drive error correction and counting-
1.)"the MMU2 unit stops printing and starts flashing continuously with red and green LEDs"- Do you mean all 5 LED's flash red/green?
2.)How does one recover a print if this error state occurs?
3.) The motors seem to be running much faster during an unload. Is this a change in the new firmware as well?
Thanks in advance.
Veröffentlicht : 09/02/2019 4:51 pm
JC507
(@jc507)
I had issues with the MMU losing track of the filament and the selector would be on the wrong filament position.
Veröffentlicht : 10/02/2019 4:16 am
JLTX
 JLTX
(@jltx)
filament unload on tool changes is insanely fast, too fast. there is a high pitch whine as it flies out of the bowden. If there is any hint of resistance, the gear instantly grinds a divot into the filament and it is ruined.
Veröffentlicht : 10/02/2019 5:09 am
JLTX
 JLTX
(@jltx)
I suspect my bowden lengths got reset and are longer, so that it subtracts more and more from the delay and hits ludicrous speed.
Veröffentlicht : 10/02/2019 5:22 am
JLTX
 JLTX
(@jltx)
Nope. Those checked out. But when trying to fine tune them, it ground a hole trying to unload at light speed and ruined another length of filament. I'm chewing through this roll faster than if I was actually printing something.
Veröffentlicht : 10/02/2019 5:38 am
toaf
 toaf
(@toaf)
I do not think it uses "bowden lengths" for unload
Veröffentlicht : 10/02/2019 6:04 am
JLTX
 JLTX
(@jltx)
I meant for speed. If you read the firmware, it starts speeding up after it unloads a certain distance. It keeps accelerating until it gets to a point near the end. So if your bowden length is long, it could end up going faster.
But this is not what is going on here. That code didn't change since 1.03 from what I can tell. Anyone else seeing stupid fast unloads with 1.04?
Veröffentlicht : 10/02/2019 4:43 pm
Colin
(@colin-4)
Yes! I opened an issue on Github. I like the speed, but the noise is an issue at night. I can hear it from another room. There needs to be a stealth mode.
"Ludicrous Speed" 😆
Veröffentlicht : 12/02/2019 1:12 am
toaf
 toaf
(@toaf)
"Ludicrous Speed" 😆
but if you cant hear it while your sleeping....how will you know it hasn't jammed? 😀
Veröffentlicht : 12/02/2019 1:40 am
AbeFM
(@abefm)
Mitglied
How are the load/unloads compared to TheZeroBeast FW? That was a LOT faster and took some months to get used to the sound.
Suggestion: Please keep fail stats available after a print.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Veröffentlicht : 15/02/2019 8:03 pm
KennyB
(@kennyb)
Hmm, this firmware changed the position slightly for the selector and how it aligns to the filaments. I can't load filament 1 anymore. Filament 2 is sort of rough as well. The previous firmware didn't have this issue for me.
Veröffentlicht : 19/02/2019 6:10 am
FaultyLine
(@faultyline)
I'm having the same exact issue. Just opened a bug about it on GitHub. https://github.com/prusa3d/MM-control-01/issues/117
Please go comment if you have a GitHub account.
Would you mind removing the FINDA and ball bearing and then shining a light and see if your selector is about 1 mm to far to the right? This is what mine is doing. I can post pics if you'd like.
Veröffentlicht : 19/02/2019 7:50 am
FaultyLine
(@faultyline)
Looks like someone else also reported it.
https://github.com/prusa3d/MM-control-01/issues/94
Veröffentlicht : 19/02/2019 8:00 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Assembly manuals
/ Knowledge Base
Veröffentlicht : 20/02/2019 11:40 am
JuanCholo
(@juancholo)
is the alignment issue on the selector only on the 2.5?
“One does not simply use a picture as signature on Prusa forums”
Veröffentlicht : 21/02/2019 5:45 pm
airdataman
(@airdataman)
I loaded this new firmware yesterday on my Mk2.5 with MMU2 (upgrade from the MMU1, which was working well) with, initially mixed results. The good news was that a three colour print of the penguin @ 0.15mm worked flawlessly with no missed layers. The bad news was that it took a lot longer to complete (>12hrs for a <10hr print) than it should have!
The best news was that the reason for the delay was obvious - the problem occurred during the filament retract from the hot end back to the selector. After the filament started to go back up the bowden tube it was obviously supposed to speed up dramatically, however in my case it actually stopped and the extruder stepper in the MMU2 made a loud noise as it was just skipping steps and not rotating. After a while this stopped and the filament was retracted very slowly into the MMU2 unit, actually stopping and reversing for a bit a couple of times in the process.
At this point it is also worth noting that my printer was one of those that was having problems with alignment of the selector after initialisation with version 1.03 of the driver - it would move quickly to the left and hit the left wall with such a large force that the wall would actually bend over and then stop, still hard against the wall.
Looking at the symptoms I realised that the most likely explanation was that the 12V supply in the mk2.5 is only marginally able to drive the stepper motors in the MMU2 at the higher speeds. I therefore measured the output of my PSU, which was set to about 12.15V and increased it by about 1V to 13.15V (beware, this may also affect/damage the heaters, fans, etc.). When running a test print the improvement was dramatic - the filament retraction was fast and much quieter. The initialisation also behaved totally differently, with the selector moving to the right wall and returning to the correct position (about 1mm from the left hand wall and correctly aligned to slot one).
I suspect that the supply voltages on the Mk2.5 units may be subtly different and also the cable resistances to the MMU2 unit may be a little variable, both of which may affect whether or not this marginal issue is seen. I suggest that it would be a good idea if Prusa and any beta testers, if they don't already, set the PSU voltage a little lower than normal during their testing such that any problems like this (which may only affect a relatively small number of users) are revealed.
The very best news is that the MMU2 that I have had since the end of November last year is now seems to be working reliably for the first time! Initially I could not get it to work for a single print, but I did get much better results after changing the bowden between the MMU2 and the hot end with one having a 2.5mm internal diameter and drilling out its connectors a little.
Veröffentlicht : 21/02/2019 10:13 pm
KennyB
(@kennyb)
That is an interesting theory. Did you flash the 1.0.4 Final firmware and see if there was the same issue (without needing to up your voltage). If what you are saying is correct, it might make sense to make a separate power supply for the mmu2 when using it with the mk2.5.
Veröffentlicht : 22/02/2019 7:27 am
KennyB
(@kennyb)
I was going to try what you asked but the 1.0.4 final firmware fixed this for me. Everything aligns now.
Colin
(@colin-4)
Does it still have the same horrible sound when unloading?
Veröffentlicht : 22/02/2019 1:24 pm
Seite 1 / 2
