FINDA is lighting when is fillament load?
Holister3D
(@holister3d)
Hi guys,
I have a question, is FINDA sensor lighting if is fillamnt loaded? My FINDA sensor is not never lighting.... :?, it is fault or not?
When I print by PLA it is not problem it is printing fine. But when I try to print dissolvable support PrimaSelect PVA+ it is not working, fillamnet break in extruder. 😥
Thank's
Publié : 25/10/2018 9:51 pm
imod.systems
(@imod-systems)
Re: FINDA is lighting when is fillament load?
If the FINDA light is off it means that it's detecting the metal ball. If the light is on that means it isn't detecting the metal ball.
If you don't have filament loaded and the light is off loosen the screw and back out the FINDA a bit until the light turns on.
Publié : 26/10/2018 12:49 pm
chris3030
(@chris3030)
Mine is finicky. Sometimes the light is on, sometimes it is off (when it is doing the exact same thing). The loading works correctly for the most part, just the light never changes during the loading process. Other times if it fails to load the filament correctly and I have to manually fix it, the light works correctly. /shrug
Publié : 26/10/2018 9:50 pm
