Filament Profiles
CLKandCJK
(@clkandcjk)
Filament Profiles
I feel like we need a good organized way for people to share what settings are working for the filaments they are using!! I think temp and ram settings are key to MMU success. Why isn't there an entire forum section dedicated to it?
So far I am finding that 5 degrees in either direction and increasing ramming time has made a lot of difference for me.
Hatchbox Black - I lowered temp
Solutech Glow in the Dark - I raised temp and increased ram time to 4
Inland purple+ and pink+ - used Chris's Pretty profile
Prusa Sliver - using Prusa profile
Maker Geeks yellow - Generic PLA profile with temp at 230
Opublikowany : 17/10/2018 4:15 pm
Paul Meyer
(@paul-meyer)
Re: Filament Profiles
Inland PLA: I'm having luck with first layer 205, print at 200, 4 second ram, 140 mm/s starting unload speed, ram temperature dropped to 180 (basically power off during RAM).
Opublikowany : 17/10/2018 10:02 pm
Joe
 Joe
(@joe-16)
Atomic PLA: 210/200 with 1.5s ram, not perfect yet but an improvement on the Generic PLA settings.
Opublikowany : 17/10/2018 10:04 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
From memory, E motor speed is limited to 100mm/s (or 120mm/s) in firmware (M203 E7200)
The actual limit is determined by the MCU and the individual motor. Pushing it above the limits causes missed steps, stringing and failed unloads/loads.
Peter
Opublikowany : 18/10/2018 9:50 am
