Filament jamming on loading
tdukes
(@tdukes)
Hello,
First post and thanks for the add!!
Bought a used MMU2S off eBay about 2 months ago. Its been working flawlessly until today.
Using default settings and printing PLA @ 215C. The tip is now a little blunt and won't reload.
Had perfect load/unload/reload with this same filament. Not sure what went wrong.
Any help would be greatly appreciated!
TIA
Veröffentlicht : 04/02/2020 2:33 am
chrisbloom7
(@chrisbloom7)
RE: Filament jamming on loading
It's a good idea to always start with a clean tip on your filament. Use some wire cutters and cut the tip at an angle. If it still won't load try following these steps https://help.prusa3d.com/article/lnbcnhg76k-cold-pull . If you can't push the filament through you may need to disassemble your hot end to see if maybe a piece of filament got lodged in or just below the PTFE tube.
Prusa MK3S/MMU2S
Prusa SL1/CW1
Veröffentlicht : 07/02/2020 6:58 pm
