converting prusa from MMU2 back to original
Andy
 Andy
(@andy-10)
to be honest the MMU2 does not work for me and as most prints i do are single colour i want to go back to original setup. how do i do this?
Opublikowany : 26/08/2019 8:02 am
Dave Avery
(@dave-avery)
RE: converting prusa from MMU2 back to original
unplug mmu cables to einsy
swap extruder parts back to mk3s
thats all
Opublikowany : 26/08/2019 12:20 pm
gnat
 gnat
(@gnat)
Posted by: david.a66
thats all
Slightly more complicated if they started with a MK3 and upgraded as part of the MMU install. At least in my case a few of the printed parts were not included (the internal lever, part that holds the ball, and top cover).
You can run the printer as a normal MK3S with the tower still in place though (either short term to print the missing parts or long term). The caveats are that autoload will not start until you push the filament into the gears (then it works normally) and the runout detection happens after the filament has gone past the gears (so it won't eject the stub).
MMU tips and troubleshooting
Opublikowany : 26/08/2019 4:32 pm
