Compatibility with mk3 sliced files
JVleugels
(@jvleugels)
I have a question specifically for our school environment.
We have 5 MK3 prusa printers and 3 MK2 printers.
With the mk2 MMU1 it was not possible to print on this machine with a file prepared for the regular MK2. Doing this would mean wrong purging of the filament and no option to select the desired color. Only slicing with single material mode of multi material mode would work.
Now is it possible with the MK3 MMU2 to print using a file sliced for a regular MK3 without issues?
It would be awesome since it is already extremely hard to make students use the correct slicing profile for MK2 - MK3.
Publié : 15/10/2018 5:44 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Compatibility with mk3 sliced files
No, the load at the start and unload at the end are different.
Peter
Publié : 15/10/2018 9:58 pm
