Cannot flash MMU firmware
JammerX19
(@jammerx19)
Trying to flash 0.9.0 onto the MMU and Slic3rPE says "flashing failed: the device could not have been found". My computer found the device and shows it in Device Manager properly as COM5. Any ideas on what to do next?
Postato : 11/10/2018 2:28 am
ad.lamy
(@ad-lamy)
Re: Cannot flash MMU firmware
Hi Jody,
I had the same problem with Slic3rPE on Linux, I found the solution here https://github.com/prusa3d/MM-control-01/blob/master/README.md , perhaps it can help even if you are a Windows user.
Regards
MK4/MMU3 - VORON 2.4 350 Stealthburner
Postato : 11/10/2018 7:05 am
nuroo
(@nuroo)
It's easy in Windows. Modifying and flashing with Arduino IDE is easy in Windows. But the easiest choice is now available:
New mmu2 firmware with precompiled hex
https://github.com/prusa3d/MM-control-01/releases/tag/v1.0.1
Just download and and use slic3r to update.....
Prusa MK3 > MK4s
Prusa MK2.5 kit > MK3 > MK3s > MK4s
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6 - taken apart for space
CR10s4 - upgrading
Delta 3ku - dont use
Postato : 12/10/2018 5:31 pm
Joe
 Joe
(@joe-16)
You are connected to the MMU via USB right, not just the printer?
Postato : 12/10/2018 5:34 pm
ad.lamy
(@ad-lamy)
Yes only connect the MMU to your PC.
Postato : 12/10/2018 7:00 pm
JammerX19
(@jammerx19)
Yes, I was only hooked directly to the MMU from my PC. It ended up being a USB port thing. I moved it to another port on my PC and it worked.
Postato : 16/10/2018 9:56 pm
