Brass connector in fs-cover-mmu2s popped out how to fix?
All,
The brass connector in the fs-cover-mmu2s just popped out all of a sudden. Pushing it back down works momentarily and then it pops back out! Has anyone had this problem before? Were you able to fix it somehow? I'm concerned to use some sort of glue so I don't end up having a partially clogged hotend or issues with the filament sensor.
If I was to reprint the plastic part I imagine it must be printed with a very dark PETG if I was to just reprint the plastic portion again, but has anyone done this with black PLA instead or would the brass connector just pop right back out again under tension?
Thanks!
Opublikowany : 30/06/2020 12:50 am
Topic starter
answered:
RE: Brass connector in fs-cover-mmu2s popped out how to fix?
Well.. I glued it in place and it seems to be ok for now.
Opublikowany : 30/06/2020 8:26 pm
