Area I'm trying to paint just moves model
I'm trying to paint a certain area with prusa slicer and every time I click in the area I need to paint it's just moving the model around. Like that's the specific area to click to rotate it around. Is there any way to turn the rotation off so I can paint in that area?
Napsal : 23/01/2022 11:13 pm
RE: Area I'm trying to paint just moves model
When this happens, are you seeing a white (or grey) circle (or white triangle) where your cursor is? If not that means that the brush is not detecting the surface of the model from your viewing angle. In that case you need to rotate the view until you can see the circle or triangle at your cursor where you want to paint. I find that often an oblique angle works better than straight on.
Mk3S+,SL1S
Napsal : 12/04/2022 4:42 pm
