Anybody timed the print speed of i3MK3S+ vs i3MK3S+ with MMU2S when one filament is used?
Hi, it looks like during installation of the MMU2S, one has to replace some extruder parts from the i3MK3S+. When only one filament is used, does it take the same amount of time to complete the same print job or it takes longer once the MMU2S has been installed?
Respondido : 15/03/2021 6:08 pm
RE: Anybody timed the print speed of i3MK3S+ vs i3MK3S+ with MMU2S when one filament is used?
I don't know if the profiles are actually identical, but they should be. The changes to the extruder are just to mount the feed tube from the MMU2 and to use a different filament sensor mechanism — none of this affects extrusion performance.
Respondido : 16/03/2021 12:43 am
