2000 tool change mark
Strona 3 / 3
nuroo
(@nuroo)
Re: 2000 tool change mark
Thats tragic @toaf
Not a fail from selector trouble, missed load, bad tip etc. Would have never considered that could happen.
Prusa MK3 preassembled (R2/B6) > (R3/B/7)
Prusa MK2.5 kit > MK3 > MK3+MMU2 (R3/B/7) 😀
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6
CR10s4
Delta 3ku
Opublikowany : 05/12/2018 4:01 pm
toaf
 toaf
(@toaf)
after a fast look, it seems 190 is max Z for me. ill look into it more after the next print.
doesn't look like it's my fault 190 is max but I have to look closer later to make sure.
Opublikowany : 05/12/2018 6:55 pm
toaf
 toaf
(@toaf)
well I had some wires sticking out that wouldn't let the extruder go above about 180/190
it looks like the filament run out raises the extruder around 20 mm or so.
anyone know how much a "crash detected" moves the extruder up?
I feel I must do science to explain why my super jedi test failed.. at least it didn't fail from filament issues
Opublikowany : 06/12/2018 7:41 am
toaf
 toaf
(@toaf)
by the way purge block weighed 1.2 pounds. at least the fail was my fault (kinda)
Opublikowany : 06/12/2018 8:02 am
John
 John
(@john-6)
And the print weighed?
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Opublikowany : 06/12/2018 10:25 pm
toaf
 toaf
(@toaf)
didn't even weigh it. not that much. I knew this test was gonna be a filament eater
Opublikowany : 06/12/2018 11:13 pm
John
 John
(@john-6)
Yeah ¾ of a whole spool of purge is … scary
Opublikowany : 06/12/2018 11:35 pm
toaf
 toaf
(@toaf)
blame the 3900 tool changes. i know i could have saved some by making the purge abit smaller.. but its ok. all about the till changes
Opublikowany : 06/12/2018 11:41 pm
JuanCholo
(@juancholo)
i printed 2 things that was over 200mm so on mine i have clearance.
“One does not simply use a picture as signature on Prusa forums”
Opublikowany : 07/12/2018 1:16 am
toaf
 toaf
(@toaf)
ya 100% my bad. the dumb useless filament sensor wire wasn't all the way in.
Opublikowany : 07/12/2018 4:16 am
JuanCholo
(@juancholo)
i can tell you that as the height increases there is a concern to how the orange tube deforms in a very upwards 'U' shape and how much more friction this introduces to the unload/load cycle.
many of my tall prints happened to end with one color requiring no color changes for the last 10-20mm
Opublikowany : 07/12/2018 4:57 pm
Strona 3 / 3
