Re: 2000 tool change mark
Thats tragic @toaf
Not a fail from selector trouble, missed load, bad tip etc. Would have never considered that could happen.
Prusa MK3 > MK4s
Prusa MK2.5 kit > MK3 > MK3s > MK4s
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6 - taken apart for space
CR10s4 - upgrading
Delta 3ku - dont use
after a fast look, it seems 190 is max Z for me. ill look into it more after the next print.
doesn't look like it's my fault 190 is max but I have to look closer later to make sure.
well I had some wires sticking out that wouldn't let the extruder go above about 180/190
it looks like the filament run out raises the extruder around 20 mm or so.
anyone know how much a "crash detected" moves the extruder up?
I feel I must do science to explain why my super jedi test failed.. at least it didn't fail from filament issues
by the way purge block weighed 1.2 pounds. at least the fail was my fault (kinda)
And the print weighed?
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
didn't even weigh it. not that much. I knew this test was gonna be a filament eater
Yeah ¾ of a whole spool of purge is … scary
blame the 3900 tool changes. i know i could have saved some by making the purge abit smaller.. but its ok. all about the till changes
i printed 2 things that was over 200mm so on mine i have clearance.
“One does not simply use a picture as signature on Prusa forumsâ€
ya 100% my bad. the dumb useless filament sensor wire wasn't all the way in.
i can tell you that as the height increases there is a concern to how the orange tube deforms in a very upwards 'U' shape and how much more friction this introduces to the unload/load cycle.
many of my tall prints happened to end with one color requiring no color changes for the last 10-20mm
