2 colour print, 2nd colour starting inside first one already
blatti
(@blatti)
Hi there,
How do I do that with Prusa slicer?
I'm trying to use 2 colours got 2 stl files and want the second colour to start inside the first (main). My intension is that the script does not fall off or break off. The Z+ should be placed inside the existing Z+ gap. Should the Z+ have a real gap of 0,01mm? So the slicer does not merge everything?
Thanks in advanced.
Stefan
if you can imagine it - if you can design it - you should print it!
Make the impossible - possible!
Opublikowany : 20/02/2020 2:36 pm
tj
 tj
(@tj-2)
RE: 2 colour print, 2nd colour starting inside first one already
You probably added the two stl files as individual objects instead of a multipart object.
Add first stl file, then right click on it in the list to the right and select add part and then load, pick your second stl file.
The objects will then be grouped a bit differently in the tree and assuming you initial modell was created properly they should align perfectly.
Opublikowany : 20/02/2020 7:24 pm
blatti
(@blatti)
Thanks - worked it out
Opublikowany : 21/02/2020 6:25 am
towlerg
(@towlerg)
@stefanb7110
Could you post a picture of your result?
Opublikowany : 21/02/2020 10:27 am
blatti
(@blatti)
here we go ...
Opublikowany : 22/02/2020 11:33 pm
towlerg
(@towlerg)
@stefanb7110
I think you sent the wrong pic.
Opublikowany : 23/02/2020 11:54 am
blatti
(@blatti)
the acctual print was previously and the original task is here.
Opublikowany : 23/02/2020 4:13 pm
blatti
(@blatti)
and one more pic
