Will there be a "bug fix summary" at some time?
martin.m25
(@martin-m25)
After first tests with my MMU2, I was severely disappointed about it. As I'd like to print, not try to figure why it doesn't, I removed it and put it in a box on a shelf. My current plan is: Wait half a year (or so), see how state of things is then, apply all fixes that have been found and try again. It seems that some users are making good progress so this does not seem too unlikely.
The question is - how do you get all this info? Will there be at some time a "how to fix your MMU2" manual? Currently, you have to sift through countless posts on this forum to find single bugfix ideas. I hope this will be collected somehow?
- Martin
- Martin
Opublikowany : 08/11/2018 5:58 pm
Nikolai
(@nikolai)
Re: Will there be a "bug fix summary" at some time?
Not at all. Got my MMU last week. Updated the firmware, made the tube length calibration for each tube like described in the manual. Done deal. Default Slic3r settings worked well without any issues.
For you I would suggest the same approach. Follow the most recent manual and make sure you have the most recent Firmware/Slic3r, configs and you're up-to-date.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 08/11/2018 7:18 pm
