Will not load 2nd filament during print
Racenviper
(@racenviper)
I have the current version loaded.
I have calibrated the feed length to the extruder.
I can pre-load filament into MMU2
I started with the Lizard print and the supplied G-code and everything is fine till the second color starts. the 1st color is unloaded. The MMU2-Selector moves to filament position "2" and the "Idler Body Assembly" rotates back to position 1, with the selector in position 2.
Any ideas what I need to do?
Opublikowany : 15/10/2018 2:34 am
Racenviper
(@racenviper)
Re: Will not load 2nd filament during print
First half shows filament will load properly
The last minute shows the failure. Filament 1 unloads and the selector move to position 2 and the "Idler Assy" stays at filament position 1
Opublikowany : 16/10/2018 3:28 am
