unknown failure /04900
Komet_82
(@komet_82)
Hello
I just recieved an error unkown failure /04900 and when I click reset MMU it takes 1 second and the message comes again.
It is a 18h MMU Print with about 500 filament changes. So faar it run preety smooth and the filament changes work porpperly. just after about 6h in the print I had a failure TMC driver failure /04321 which I could resolve with Reset MMU
But the one /04900 not.
Any triks that I can still finish the print. Any Ideas where this could come from? I have just recently updated firmware and software, and had 2-3 smaler MMU flawles prints
Many thanks for your support
Cheers
Markus
Posted : 30/01/2024 11:40 am
Robin
(@robin)
RE: unknown failure /04900
Probably not what you where looking for, but hey: https://help.prusa3d.com/article/unknown-error-04900-mmu_484853
If you are using an unmodified MMU2 this might be the equivalent to the old "all lights flashing"-error, so upgrading the MMU powersupply might help (see corresponding thread: https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/i-found-serious-design-error-in-mmu2-electronics-hardware )
Posted : 30/01/2024 3:21 pm
Komet_82
(@komet_82)
Hi Robin
Thanks, yes the link above I saw, but yes...
The bottom one I did not know, but I'm a bit affraid in working on the powersupply. Should I consider an upgrade to MMU3 with an MK3S to MK3S+ upgrade?
I really like the MMU approach and would love to to some large prints on it. And at the moment it seems mechanically working pretty smoth.....
Thanks
Cheers
Posted : 31/01/2024 6:59 am
Robin
(@robin)
The mod with the additional buck-converter is cheap and easy to do - my MMU2 works nicely since I did that mod.
The MMU3 upgrade comes with a little board to deal with the power problem, so: yes doing the MMU3 upgrade will fix the same issue and probably your problem.
Crashing TMC drivers are an indication of the voltage drop thing…
ps: you do not need MK3s to MK3s+ upgrade for the MMU3 upgrade by the way.
This post was modified 2 years ago by Robin
Posted : 31/01/2024 9:57 am
Komet_82
(@komet_82)
Really, I thought I have read somewhere about the need to have MK3S+ for MMU3. So this saying I'm fine with my standard MK3S to run the MMU3? If this is the case I think this really should be my way to go
Thanks
Posted : 31/01/2024 11:57 am
Robin
(@robin)
No, you can use the MMU3 (upgrade) with the MK3S, it‘s not recommended, but possible. Just be careful with the extruder parts and pay attention to the differences (PTFE etc).
see: https://help.prusa3d.com/article/mmu3-firmware-compatibility_470808
Posted : 31/01/2024 1:26 pm
Robin
(@robin)
If you do not want to mess with the power supply: search Ali express for “MMU pd board” and just install that, that should do the trick.
Posted : 31/01/2024 1:32 pm
Komet_82
(@komet_82)
I think I just go the safe route with MK3S+ and MMU3
Thanks for the support
Posted : 31/01/2024 7:49 pm
