Soluble material wont print
jgarv743
(@jgarv743)
Im not sure this is the exact right forum so let me know if I should change locations. I am trying to print a propeller with the soluble interface (have also tried soluble full). I have my soluble material on ext-5 and the PLA on ext-1. In slicer I have the Verbatim BVOH selected on ext-5 and when i slice everything seems to be correct. There is a soluble layer, and a PLA part/supports. After putting the g-code on a sd card and starting the print, the printer will say it has switched to filament 5 and then continue to use the PLA instead of the soluble. Is there a setting somewhere I am missing? Is this a slicer issue?
Thanks in advance
Napsal : 19/10/2018 3:35 pm
