Slic3r MMU2s Filament Profiles
aepoc
(@aepoc)
What happened to the Colorfabb profiles? Can I print with different temps for each filament or do all 5 filaments have to be the same type/brand?
Respondido : 22/04/2019 3:28 pm
Tiger3DPrinting
(@tiger3dprinting)
RE: Slic3r MMU2s Filament Profiles
all of the profiles for the prusa mmu2 have been tested by prusa, and the colorfabb filaments have not yet been tested to get the right settings, so if you are printing with multiple colors, then you cant use them unless you make your own. in the mmu2 single mode you still have access to all of the old profiles, but you can only use one color. you can print with different temperatures for each of the filaments, but it is not suggested because the printer will have to heat up or cool down  lot, and sometimes the different filaments don't stick to each other. I would suggest using only filaments with very similar printing temperatures, like PLA, and PVA for support material, although PVA is kind of hard to print with.
Respondido : 25/04/2019 4:17 am
