Ramdom filament change request from the MMU2S unit
Lvet
 Lvet
(@lvet)
Hello,
From now and then in the middle of a print, the MMU2S stops and ask to load new filament, with the message "Remove old filament and press the knob to start loading new filament".
It's rather bizarre, because the spool in nowhere to be near its end.
How does the MMU2S unit detects that the filament spool is finished ?
This topic was modified 7 years temu by Lvet
Opublikowany : 19/10/2019 2:21 pm
Zoltan
(@zoltan)
Member Moderator
RE: Ramdom filament change request from the MMU2S unit
Does this seem to you familiar?
https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-assembly-and-first-prints-troubleshooting/how-to-fix-the-ir-filament-sensor/#post-169015
Opublikowany : 19/10/2019 5:45 pm
Zoltan
(@zoltan)
Member Moderator
Is this message connected with a extruder move abit up and to the right side of the bed?
Could be some filament sensor misinterpretation - does it concern transparent filament or filament type independent? Could you provide as much as possible info? This can help yourself to look for solution and also other experienced users who are willing to help even they do not encouter your issue?
Opublikowany : 19/10/2019 5:55 pm
huskyte
(@huskyte)
Had it, been there, .... It can be caused by the filament IR sensor flickering. Readjust the sensor, solder an LED on there. The LED tells you the whole story (I was really surprised when I saw my supremely calibrated sensor the first time with an LED as indicator, man, was I far away of what I wanted). Keep in mind that a non-robust adjusted sensor might trigger differently on different position of the extruder due to small deformations of the housing.
Opublikowany : 20/10/2019 8:32 am
1 ludzie polubili
Lvet
 Lvet
(@lvet)
The problem appear to come more often with a PETG white filament (non transparent) and a black PLA filament (this filament appear to be slightly thinner than the standard 1.75mm). Other than that everything is pretty standard.
I suppose we are talking about the IR sensor on the extruder.
@Michael-t66, where exactly should I solder the LED (and the load resistance I suppose). Is it ok if I place this between the ground and the output?
Thanks
Luca
Opublikowany : 20/10/2019 9:04 am
huskyte
(@huskyte)
First: Yes, IR sensor on the extruder.
This is exactly what I was also experiencing, thinner filament and more misfiring. But the sensor can easily be adjusted to manage that. The easiest way was the LED idea (not mine), as well as a few tweaks to the position of the sensor.
I do not have the correct link to the LED, but you might find it. One that is similar is: https://www.thingiverse.com/thing:3578659 . It is +5V and out. If you go for a standard LED connect a resistor in series to limit the current. I personally had some lilypad LEDs left over that have the resistor onboard.
Opublikowany : 20/10/2019 9:13 am
Lvet
 Lvet
(@lvet)
Thanks for the link and suggestion. I have plenty of standard LEDs lying around, I will test the mod by soldering the resistor and the LED on the wiring. If it works I will make it "pretty" later 😀
Opublikowany : 20/10/2019 10:13 am
huskyte
(@huskyte)
@luca-vicini
Just did another one
Opublikowany : 20/10/2019 1:10 pm
Marino
(@marino)
I know it is an old post but I faced the very same problem now.
I would like to add my small grain of sand. What I noticed is that the sensor is loose in its support (the chimney) no matter how much tight is the screw. It is the possible that, on the occasion of some fast movement of the extruder, the sensor moves and detects lack of filament, etc.
What I did, although I consider very valuables and helpful the proposal made in this post, was to sand a little bit the top of the chimney and add a thin paper washer between the top cover and the sensor.
This helps to keep the sensor quite steady in its place and now I do not face any problem.
Another solution would be to design the top of the chimney with less clearance with the sensor PB..
Opublikowany : 24/11/2020 4:44 pm
StJimmy72
(@stjimmy72)
You're a lifesaver. I spent like an hour trying to fix this and you saved my print. Thanks, definitely gonna get an led!
Opublikowany : 01/02/2022 5:53 am
