Q: Problem with setting the "Bowden" length (for longer bowden)
Stano
(@stano)
Hello,
Can anyone help me how to calibrate "Bowden" lenght (from MMU to extruder) when bowden is about 2x longer than the original (MMU I have outside the IKEA box)?
through the left push button we get the filament up to about 2/3 of the bowden, not more (some counter reaches MAXvalue?)
thank you
Stanislav
Publié : 28/10/2018 9:05 pm
maikel.d
(@maikel-d)
Re: Q: Problem with setting the "Bowden" length (for longer bowden)
I wouldn't recommend changing the setup of your spools too much. Longer distance might result in more friction an margin for errors. If you would give it a try I'd look in slic3r under printer settings -> single extruder MM -> park position. I don't really know much more than that, since I'm just using the original setup with different lengths before the MMU module.
I make things
Publié : 30/10/2018 10:48 pm
Stano
(@stano)
necessary parameters are in permanent_storage.cpp :
static const uint16_t eepromLengthCorrectionBase = 7900u; //!< legacy bowden length correction base
static const uint16_t eepromBowdenLenDefault = 8900u; //!< Default bowden length
static const uint16_t eepromBowdenLenMinimum = 6900u; //!< Minimum bowden length
static const uint16_t eepromBowdenLenMaximum = 10900u; //!< Maximum bowden length
S.
Publié : 01/11/2018 6:24 pm
