New question: converting a gcode file for i3 MK3S to an MMU2S compatible file
Lvet
 Lvet
(@lvet)
Hello,
I have several gcode files, sliced for the i3 MK3S. Is there a way to use these files for the MMU2S single profile?
I suppose I have to change the initial set of instructions in the file. Is there a guide around for this?
Cheers
Luca
This topic was modified 6 years temu by Lvet
Opublikowany : 20/10/2019 1:02 pm
Lichtjaeger
(@lichtjaeger)
RE: New question: converting a gcode file for i3 MK3S to an MMU2S compatible file
You don't need to change the files:
  1. On your printer select "Load to nozzle"
  2. Choose the MMU Slot
  3. Purge to clean filament
  4. Print from SD using your old files
  5. When you are done with old files select "Unload filament"
That's all.
Opublikowany : 20/10/2019 2:02 pm
Lvet
 Lvet
(@lvet)
Thanks  lichtjaeger,
Now I understand better the process.
Opublikowany : 20/10/2019 2:51 pm
