New question: converting a gcode file for i3 MK3S to an MMU2S compatible file
Hello,
I have several gcode files, sliced for the i3 MK3S. Is there a way to use these files for the MMU2S single profile?
I suppose I have to change the initial set of instructions in the file. Is there a guide around for this?
Cheers
Luca
This topic was modified 6 years ago by Lvet
Posted : 20/10/2019 1:02 pm
RE: New question: converting a gcode file for i3 MK3S to an MMU2S compatible file
You don't need to change the files:
- On your printer select "Load to nozzle"
- Choose the MMU Slot
- Purge to clean filament
- Print from SD using your old files
- When you are done with old files select "Unload filament"
That's all.
Posted : 20/10/2019 2:02 pm
Topic starter
answered:
Thanks lichtjaeger,
Now I understand better the process.
Posted : 20/10/2019 2:51 pm
