[MMU2S] loading is ok, changing filament is not working
Lemaille G.
(@lemaille-g)
Hello,
I can't print every thing in single mode. But when i make 2,3 4 extrudeur piece : the print fill only with 1 extruder.
So i flash the firmware, calibrate fina and pina (twice) but nothing happen. I use PrusaSlicer with octoprint (i also try to print from SD card).
And Support still not help me yet (waiting for reply since a week).
Any idea and solution ? Thank you !
Best Answer by Robin:
You need to set Octoprint for the use of the MMU: Under Settings - Printer Profile, click the pencil to edit the configuration. Under “Hotend & extruder,” set “Number of Extruders” to 5, and check the box next to “Shared nozzle.”
Posted : 04/09/2021 5:17 pm
Myf
 Myf
(@myf)
Change the printer in prusaSlider
Hello,
I describe an error I made. I forget to change the printer in PrusaSlicer : mk2s + SingleMmu for one color printer, and mk2s + mmu for multi-color prints.
Have a nice day !
F. (from France)
Posted : 12/09/2021 12:26 pm
Lemaille G.
(@lemaille-g)
Reply [Change the printer in prusaSlider]
This is not working, i try to select MK3S + MMU2S again, and try gcode sheep from prusa.
Posted : 13/09/2021 7:02 am
Zoltan
(@zoltan-d-2)
Member Moderator
Re
Before multicolor print use the command load all ,this will check that all your filaments are correctly prepared for filament change.
Posted : 30/09/2021 2:27 pm
Robin
(@robin)
octoprint settings
Posted : 04/10/2021 9:54 am
Lemaille G.
(@lemaille-g)
Best reply
thank you, all work !
Posted : 04/10/2021 9:59 am
