MMU2S all red and green LEDs are always turned on
Nullzero
(@nullzero)
I upgraded my MK3 to MK3S/MMU2S over the weekend, and I think I got it right.
But I'm having a problem with the MMU2S not working correctly.
When I power on the machine, the MK3S portion boots up fine. I can calibrate, move the axis around, use the hotend etc.
However, the MMU2S is unresponsive. All red and green LED lights are turned on (but not blinking). I can press or hold the buttons, but nothing happens.
Things I have tried:
- flashing the firmware on the MMU2S multiple times. It's successful every time.
- adjusting and tightening the screws inside the eletronics box, that have the power cables connected. No change in behavior.
- checking the power connect to the MMU2S board. The cable is correctly seated on the board.
- Oddly, if I press the reset button on the MK3S, the MMU2S resets, and the right-most green LED is weakly blinking. But the result is the same, with unresponsive button presses.
Another strange phenomenon: if I plug the MMU2S into my PC via the USB cable, it starts working. The LEDs change from red/green to a single green LED, and I can use the buttons to move the selector head. I can tell the MMU2S to load filament. But as soon as I unplug the USB cable from my PC, the MMU2S goes into a zombie state again... and is unresponsive.
Is this a power problem, perhaps? Maybe the MMU2S control board is not getting enough voltage or something? But the USB gives it plenty of power? I am in Japan, so the mains voltage is only 100V from the wall socket. Could that be a problem?
I also have a very early MK3 machine. One of the first pre-orders, I'm sure. Could the electronics be different some how?
Thank you.
Postato : 08/04/2019 12:59 pm
Strange_Prints
(@strange_prints)
Re: MMU2S all red and green LEDs are always turned on
I was having this problem today, I spent ages trying to figure it out!
Eventually I tried taking all the wires out and putting them back in, what I noticed was that i had put my signal cable all the way to the left in its area. but i noticed in their picture they have a little spacer that shifts it one pin to the right. I moved it to the right and the mmu2s suddenly came to life. Not sure if its the same problem for you but that fixed mine.
Postato : 09/04/2019 5:27 pm
Nullzero
(@nullzero)
Wow, thank you so much! This was EXACTLY my problem!
My Einsy board doesn't have this orange buffer. So I was plugging my signal cable one peg too far to the left! I shifted it one over, and now the MMU2S appears to be working! Woot!
Postato : 09/04/2019 9:58 pm
1 persone hanno apprezzato
