MMU2.0 with MK2.5
mark.w19
(@mark-w19)
MMU2.0 with MK2.5
Has anyone connected MMU2.0 to a MK2.5? The installation manual only showed how to connect the power and signal connectors to the new MK3 board. I improvised the MMU2.0 power connectors to the PSU power connectors on the board, and connected the signal connector to the only 5 pins left on the board. The MMU powered up and initialized, but gives a constant noise. The printer also does not recognize the MMU.
Napsal : 20/09/2018 6:01 am
toaf
 toaf
(@toaf)
Re: MMU2.0 with MK2.5
did you ask in "live chat"?
Napsal : 20/09/2018 7:20 am
nuroo
(@nuroo)
You are brave...
Idk maybe reverse the connector? ( No liability ) just a suggestion since you are a brave one.
Maybe you'll have move the pins in the connector. Best to get official answer..
Prusa MK3 preassembled (R2/B6) > (R3/B/7)
Prusa MK2.5 kit > MK3 > MK3+MMU2 (R3/B/7) 😀
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6
CR10s4
Delta 3ku
Napsal : 20/09/2018 4:50 pm
mark.w19
(@mark-w19)
I think the MMU power connectors are connected to the PSU connectors on the MK3 boards, so I figured it's probably OK. Signal connectors won't damage the board at least. I tried to reverse the connector, but the printer won't even boot up and gave me a blank screen on the LCD. So I think the signal connector pins have to be re arranged somehow for the MK2.5 board.
Napsal : 20/09/2018 9:37 pm
joreal
(@joreal)
We have issue on MMU2.0 with MK2.5:
https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f53/mm-2-0-mk2-5-mk3-does-not-work-with-mk2-5-t24797.html#p109147
Napsal : 27/09/2018 5:45 pm
