MMU2 not detected
dexter.c
(@dexter-c)
MMU2 not detected
I finally finished assembling my MMU2 along with the mk3s upgrade. Everything looks good when it comes to connection and the such, and the unit powers on, but all it does is turn on one green led all the way on the right. The unit also doesn’t show up on in the support menu in the printer.
I’ve tried flashing different versions of firmware, new and old, to both the MMU and the printer, but still the same issue. Has anyone experienced to his before and know how to fix this?
Opublikowany : 17/05/2019 9:01 pm
gnat
 gnat
(@gnat)
RE: MMU2 not detected
If you are absolutely 500% sure that all your connections are plugged in properly and well seated, then a faulty board is probably the only other option.
Triple check your connections (ideally with another person looking at it too) and then talking to support is probably going to be your best course.
MMU tips and troubleshooting
Opublikowany : 18/05/2019 1:31 pm
Joe McDougald
(@joe-mcdougald)
I've just run into this.  I haven't double checked the connections, so that's my next step, to have someone double check my work.
Opublikowany : 18/05/2019 1:59 pm
