MMU2 Initialisation of Idler not correct
Hallo,
I just finished the new upgrade kit, but I have the impression that the resetting of the idler is not correct.
If I open the idler base to check the function and switch on power the initialisation of the idler starts twice; the first time the idler turns without problems, the second time it turns only some steps up to the stop and rattles sometimes. If I close then the idler base, the bearing for F1 is not directly above the pulley, but more in direction to outlet. If I turn the idler manually two or three steps backwords (with power on), I can close the idler base and all works very well.
My printer is a MK2,5 and I flashed 1_0_2.
Many thanks for your help
Klaus
Napsal : 02/11/2018 5:46 pm
