MMU2 getting mixed up
Flack
(@flack)
Just tried printing the PLA sheep off thingyverse, I have just got my MMU2 setup with my Prusa Mk3, it failed first time around because of a filament snag after quite a few changes in to the print.
But when I restarted the exact same print from the start the MMU2 according to the lcd screen was loading F4 from F1, but the MMU loaded F2 filament instead, as anybody seen this error before ?.
Postato : 14/12/2018 7:42 pm
JuanCholo
(@juancholo)
Re: MMU2 getting mixed up
jam most likely caused the stepper to miss step so the homing is incorrect. power off and on to reset the MMU2 and rehome.
“One does not simply use a picture as signature on Prusa forums”
Postato : 14/12/2018 9:21 pm
Flack
(@flack)
Hi Daniel it was long after the jam had been sorted, it just decided to load a different filament than the one listed on the LCD, I just reset it and started again and up to now its going ok in to a 6 hour print of the same sheep ..
Also my purge tower keeps separating with a gap on the back of the tower were the layers are lifting, it did this on the other tower on the first print, is that my Z height not quite right.
Postato : 14/12/2018 9:49 pm
