MK3S with MMU2s
Hi, I just installed the MK3S update on my MK3 with MMU2.
My issue is that as soon as the filament reach the IR sensor, the mmu release the pressure and the filament doesn't reach the extruder gear causing the filament not loading, it's missing about 1/4 to reach the extruder gear. The IR sensor is working right, I manually tried several amount of time, the FINDA is also working right, it's detecting the filament like it's supposed to!
I am running the MK3S with MMU2s driver.
Thank you !
Attachment removed
Attachment removed
Opublikowany : 17/05/2019 1:07 pm
RE: MK3S with MMU2s
Is that picture your extruder as it is currently? If so, that is not the correct MK3S setup for the MMU. It should have a "tower" on top to accommodate reorienting the IR sensor.
Opublikowany : 17/05/2019 1:55 pm
