Mk2S MMU1 -> MK2.5 MMU2 - What printed parts are actually in the box?
Greybeard3D
(@greybeard3d)
Both upgrades are finally coming tonight. I have a few hours to print parts. I have watched a live unboxing but the guy did not cover the printed parts too well. The manual says what is preprinted, but I saw several conflicts with the unboxing video.
Someone who actually bought the MMU1->2 upgrade, what printed parts were really in there and what did you have to print?
Respondido : 23/11/2018 2:16 pm
Re: Mk2S MMU1 -> MK2.5 MMU2 - What printed parts are actually in the box?
there will be six posts each with three pictures
First the MOST Important items Gummi Bears to slow your build rate and give you time to contemplate the instructions
Build manual,
this is included to alert you to the fact that there is a need for better pictures.... and lived experience updates... these are available on - line
https://manual.prusa3d.com/c/Original_Prusa_i3_MK2S_MMU1_to_MK25_MMU2_upgrade
https://manual.prusa3d.com/c/Original_Prusa_i3_MK3_to_Multi_Material_2_upgrade
Electronics cove, extruder cover, brackets
Respondido : 23/11/2018 3:23 pm
Black B7 extruder housing, Orange fan nozzle, cable ties, split cable braid, hardware
MMU controller board
Mk3 Power cable,
Data cable and hardware
Respondido : 23/11/2018 3:28 pm
rubber feet for filament holders (there are 5 vaccuum moulded filament holder bases, not photographed
Rollers bearings etc, for filament holders
plastic filament tension arms
Respondido : 23/11/2018 3:30 pm
Idler Bearings and hardware
Idler body and housing
PTFE Tubes
Respondido : 23/11/2018 3:34 pm
ONE Motor for the selector, THREE Motors need to be recovered from the MMUv1 upgrade one to rotate the selector barrel, one to rotate the filament feed hobbed gears, and one to replace the direct extruder motor that is missing
Hobbed pulleys and hardware
Pulley body and selector parts
Respondido : 23/11/2018 3:41 pm
Micro USB cable and Mk2.5 Power cable
Tools
Spare hardware
Respondido : 23/11/2018 3:44 pm
That's all folks....
Respondido : 23/11/2018 3:49 pm
Greybeard3D
(@greybeard3d)
Thank you Joan. That was helpful. I printed everything but had to reprint the little hinges and that post which helps hold the cable because it kept detatching from the bed. And now the little extruder door is warping while printing so I’m on my second try of that.
Respondido : 25/11/2018 1:19 am
kawracer
(@kawracer)
Which package is the Filament sensor? I can not find it in any package?
Respondido : 27/11/2018 5:47 am
