Is there supposed to be a big hole in the side of the extruder?
Does this look right after installing the MM2S upgrade? I feel like there shouldn't be a huge gap here, but maybe I'm over thinking it?
Best Answer by --:
Are you concerned about the hexagonal inspection viewport where you can see the Bondtech gears?? That's normal.
Postato : 24/02/2020 4:54 am
RE: Is there supposed to be a big hole in the side of the extruder?
Postato : 24/02/2020 9:01 am
And if you mean the opening where you can see the metal heat sink, that's normal too — Prusa removed the grill that was present on the previous MK3 extruder design to get better airflow. And there's also empty space between the diagonally-mounted print fan and the rest of the extruder.
That covers everything I can see in the picture.
Postato : 24/02/2020 4:10 pm
Topic starter
answered:
@tim-m30 yep! Thanks!!
Postato : 24/02/2020 8:47 pm
